It is currently Fri Jul 18, 2025 12:43 am
PostPosted: Sat Apr 18, 2015 8:14 am
First name: Dean
Last Name: Miller
City: Buford
State: Georgia
Zip/Postal Code: 30518
Hello,
I was wondering if anyone has a schematic for a Stratocaster which has three-four wire humbuckers?
Dean
PostPosted: Sat Apr 18, 2015 9:42 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
There are several configurations depending what components you plan to use:
http://www.seymourduncan.com/support/wi ... m_1v_2t_5w
http://www.seymourduncan.com/support/wi ... =3lh_1v_5w
http://www.seymourduncan.com/support/wi ... h_1v_1t_5w
There are others with P/Ps.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Sun Apr 19, 2015 12:23 am
First name: Dean
Last Name: Miller
City: Buford
State: Georgia
Would there be any difference electrically between the mini's and full-size Humbuckers? Also would the value of the capacitors change when using the full-size compared to using mini humbuckers?
Dean
PostPosted: Sun Apr 19, 2015 6:03 am
Last Name: Wilson
Country: Scotland
Typically the mini's run 500k pots and 0.22 caps, same as full size.
Brian.
PostPosted: Sun Apr 19, 2015 7:11 am
First name: Dean
Last Name: Miller
City: Buford
State: Georgia
Brian.
Thats is kinda what I thought too. Even on the Seymour Duncan web site they said they recommend 500K for Humbuckers. (If I remember correctly) But their diagram is showing 250K
Dean
PostPosted: Fri May 01, 2015 4:08 pm
I'm rewiring my Black Beauty 3 complete with new pups. I found a 6 way switch which fits the LPs and looks like the std one. It's called a Freeway. I am also going for a 3V 1T setup. All push-pulls. I'll end up with total control of the combination of pups and switchable from series to parallel.
Sent from my Nexus 7 using Tapatalk
PostPosted: Fri May 01, 2015 7:01 pm
First name: D
Last Name: S
AR15DCM wrote:
Brian.
If you are talking volume pots, use 500k for humbuckers. 250k will knock out some of the high frequencies which is quite noticable.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat May 02, 2015 6:19 am
Last Name: Wilson
Country: Scotland
Yep. Tried this with a LP clone once apon a time and didn't like it. The mini humbuckers are basically just a small bucker, treat it as you would any other pickup of that type. Had a 70s deluxe in battered/bruised wine red for a while, never got on with the minis on the tone side of things to be honest but they do look cool.
My guess is the diagram you are looking at is a mistake dean. Unless for some reason the Seymours need the 250k to make it sound good? Lol anythings possible. If it were me I'd email them.
PostPosted: Wed May 20, 2015 1:52 pm
First name: Dean
Last Name: Miller
City: Buford
State: Georgia
I am going to use 500k pots. But to add a twist I might use the Seymour Duncan TS-1 Triple Shot Mounting Rings which allow me to turn on/off half or all of a humbucker at will without adding a bunch of switches and wiring.
That's why I just want standard wiring for three humbuckers :-)
Dean
